made some progress today - Karmann Ghia
any more updates on the Karmen Ghia?
Yes, in February I disassemble it again and sanded it with 600 grit and sprayed another two coats of Southernpolyurethane clear.... turned out even better than before.
Have not done much since then....
Well... it's been a while.... not much progress but I managed to get it outside to wash it...
I think the rear is too low. I'll have to move the swing arms one notch on the torsion bar to raise it a little ... fun fun fun....
Nice work! So you garage painted the car? I'm planning on preppung my car right after the interior is done and try painting it.
How much work do you have left to do Karsten?
let's see....
- raise the rear one notch
- cut center tunnel and fix clutch linkage
- interior: carpet, seat covers, door panels
- windshield
- instruments/stereo
another two years and $1500 :sweat::D:huh2:
How do you like this product???
I have yet had the chance to try any.
But will as soon as I get the shop up and running.
I like it a lot, it is very easy to work with. I called them and placed my order, the guy I talked to took time to explain the differences between their clears and asked where I am using it and what I was painting. It probably didn't take long for him to figure out that I was not a professional painter :lol:
Did you answer......in my driveway and on a car?:lol:
I wooda said that, and with a roller/brush.....maybe as well for all the results I got....:hissyfit::lol:
Found this today, very interesting information..... takes like 22 seconds to get to 55mph.... I might have to do something to the engine to fix that....first I have to get the interior done and get it on the road....
I'll look around, I have a 2 stage Weber brand new in the box (from the 70's) for an old 914 conversion and I may have the intake tubes too. You can have them if I can find them.
Might also have the oil cooler adapter and cooler to move the oil cooler from blocking #3 cyl.
Then add a real oil filter and you're good for a 1/2 million miles.
If I remember right, you can go 1600-1700 with the old 1350. Been a long time since my dune buggy days. With Noonies intake set up, and headers/exhaust, you just might break 20 seconds.:lol:
Thanks, that would be awesome !!! Is that the dual carb setup ??
Mine is 1500cc so with new cylinders/pistons and crank you can get up to 2200cc. The cylinder walls get kinda thin - 1800 seems to be the best compromise between performance and reliability.
Are you going to do any mods so you can beat semi's and school buses in the 1/4 mile :thumbs::thumbs:
FAST FORWARD to 2012......
Update:
I decided the blue paint has to go.... started to strip the paint and will paint it plain jain red, no pearl, no metallic just "red"
I had two spare doors that came with the car when I bought it. Since I like the clean look I decided to shave the door handles and also weld the window slot shut. These doors are a simple bolt-on so if I don't like it I can always swap doors quickly. The car won't have AC so why windows ??? LOL
there was some rust at the lower door lip
cut out rust and replaced with new steel...
in primer.....
:smash::smash:
more progress:
the door is just sitting there, no hinges..... with the hinges the fit is much better :D
getting serious..... :lol:
ran out of shielding gas so it's only tack welded in place .... fit's pretty good :cool::cool:
I finally found a good roof, had it shipped from Texas..... now it's back to original... one of the previous owners cut the top off and it's just way too much $$$ to make it look right..... with an aftermarket top it always looks like a hackjob.....
Looking great, with a hard top it should be much more solid and much easier to cool with A/C. Living in FL that should be a must.
