That's the 3/8 feed line to the pump. The hardline is on top of the frame rail. The hose from that hardline to the pump is not supposed to be outside the frame rail. It is a pre-formed line so it won't kink. I'll bet that in the past someone replaced the S bent line with off the shelf hose, it kinked and shut the fuel off. They figured out what was happening, and replaced it with the hose you see.
