Intake manifold welding (on the car): Am I lazy doing it this way??
I removed the plenum divider a few years ago to see if there was any resulting upper RPM power gain. According to my buttometer it may have helped. But, no pun intended, the idle quality really took a hit, probably from cylinders 5&7 interacting in the plenum. So, I want to weld a divider back into the plenum. Since I currently am out of ideas on how to remove more weight out of the car, I seem to have more time to be annoyed at noisy exhaust tubing and crappy idle quality.
I was getting ready to pull the intake off the engine, and then I got to thinking, can I just stuff rags in the runners, and tape off other internal surfaces to catch any weld spatter. The engine hasn't been started in months, so there shouldn't be any pooled gasoline in the ports. My biggest concern is just keeping the process crap-free, so I don't end up injesting some trash into the cylinders when I eventually start the engine again. I'm just looking for advice in case I'm neglecting something.
Thanks,
Mike
Mike,
If you have the ability to TIG weld in the divider, you could secure it with some small stitch welds and reduce the potential to get any mess into the engine. Make sure you ground as close as possible to your welds and maybe disconnect all the electrical around your distributor just in case some current tries to find a path through there. Disconnect the battery of course, but I'm sure you've done that already since it's been down for a few months. The big chicken in me would just pull the intake though to keep Murphy's Law at bay. I seem to have a hard time getting away with the short cuts...
Matched the ports from my Ramjet intake to my heads doing what you describe. No welding but lots of aluminum shards from the burr. I used a urethane material that someone gave me that was super soft so you could use it like putty but you couldn't tear or shear it. Sort of like a really soft Stretch Armstrong (if you remember that). So i filled the intake port in the head with about 2" of the port entry exposed. It worked well. The shards of aluminum stuck to the urethane and I was able to pull it out as a unit when I was done.
What about making a piece and epoxying it in place? Maybe with some pins to hold in place?
Thanks for the input, guys. I appreciate it. As much as I enjoy making performance/weight improvements to my car, I have an equal amount of dislike for spending time to repeat tasks or rectify my mistakes (given my track record of mistakes one would think I should be used to this by now;)). I have a TIG welder, and despite my being painfully slow when welding aluminum this way, this should be a small job.
And, thanks again. As much as I dread the gasket/sealant/coolant mess cleanup when pulling an intake, I suppose an upside would be the opportunity to look at the cam and lifters to see if everything is okay. I'm just trying to figure out what side of the fence I'm going to land on.
I also have to keep reminding myself that this is just a first world problem, and unimportant in the grand scheme of the universe.
In the event that I happen to get a sudden burst of motivation and energy this spring, I thought it might be prudent to have a set of intake gaskets handy. I went on our favorite online auction site and I can't believe the price of the gaskets these days. Most are at least twice as expensive as I recall, and some are three times the old price. Thankfully I'm in no rush, so at least I can look around a bit before spending the money.
Well, as usual, things aren't going as smoothly as I think they should. I cut and filed a new divider for the plenum, and the next steps are cleaning and masking the plenum area to keep trash out of there while I'm welding. I removed a few years worth of dust off my TIG machine, and prepared to do a couple practice welds to see if I still retained the minimal TIG skills I used to have (I've been MIG'ing all my aluminum welding the past several years.), and when I went to plug the welder in I see that it doesn't fit the extension power cord I use with the other (MIG) machines. Until now it hadn't dawned on me that I apparently haven't used my TIG since I moved to this present house. I make no claim to be an expert in 240 wiring, but a quick look at an online chart seems to indicate that both the welder plug and the extension cord receptacle are 50A pieces, but they're different configurations. I'm at the point where I need to make a short adapter cord, but I welcome opinions or reasons why I shouldn't do this.
Thanks,
Mike
I did the same for my MIG and air compressor. I did repurpose the drier power socket as we moved the W/D inside. But - the MIG and air compressor have different plug configurations - so I just made two extension cords from some 50 amp shore power cord I pulled from the boat. Each has a plug that matches the drier socket - again a different configuration. You'll do well I'm sure.
I didn't realize you were MIG on Aluminum. I have a spool gun and have been considering that too. Another gas cylinder I suppose.
Well, struck out at a couple of the local home improvement stores trying to find the right pieces to make my adapter cord. Tried McMaster-Carr's website last night, and for some reason the parts/pieces were outrageously expensive, Got one more big store to try, and also an electrical supply house that's buried in a nearly inaccessible industrial park. If I continue to strike out on what should be a simple wiring task/project, I think I'll just MIG the divider and get the car running again.
Edit/Update: Stopped in at Menard's yesterday, and to their credit they stocked the adapter parts I needed (pretty much). One of the connectors was different (updated) than my present piece, but a little time with a hacksaw and a carbide bit made it fit the corresponding receptacle. Hoping to finish the wiring today, and then try to get rid of some of the rustiness in my TIG skills. Thus continues my experience with most of my projects taking three times as long as I initially assume.
Well, spent some time brushing off the dust and rust from not TIG'ing for a few years. After all this time and work to get to use the TIG welder, I think I convinced myself to use the MIG spool to weld the divider in. I don't think I am coordinated enough to work the TIG torch with one hand while using the other hand for the filler rod, and doing this while bent over the fender and operating the foot pedal with my right foot. MIG'ing aluminum doesn't look as pretty as TIG welds, but these welds are going to be hidden under the carburetor where only I will know what's there.
Well, got the divider welded in, using the spool gun (no plenum explosion or fires during the process, thankfully). Some of the welds look okay, but others weren't terribly pretty as I had to weld blind with the nozzle blocking my view of the arc. I'll get my shop vac and air grinder hooked up tomorrow and do a bit of clean up on the unpleasant areas in the plenum. If this change results in a noticeably better idle quality it will have been worth the time and effort.
Well, the temps got above 60* today so I started the engine, and to my relief no odd noises or smoke out of the tailpipes, so it looks like there wasn't any major trash inside the intake that escaped all the vacuuming I did during the grinding and filing stage. Once things warmed up a touch I was pleased to see that the idle vacuum reading was slightly steadier. It had previously hunted between 11 to 13" at 800 RPM, but now it was hunting between 12-13". I did several changes and tweaks to the carb and the vacuum lines, and got the system to wander between 13-14". Next week it's supposed to be in the mid seventies, so I'll spend some more time then tweaking things.
The basic things I worked on today was trying to get the engine to run smoother while leaning out the idle mixture. In addition to playing with the mixture screws, noticeable improvements were seen by feeding raw air (sourced from the ported vacuum nipple) into the plenum (similar to an IAC system in FI setups), which allowed the throttle blades to be closed further to reduce the idle speed, which allowed the transfer slots to be less exposed, leaning the mixture further.
The engine certainly isn't silky smooth, and never will be, but I'm pleased with the improvement so far.
I'm thinking on trying another item to hopefully help the low speed drivability of my car. My present gearing setup (M21, 3.08 rear gear, and a light flywheel) is not ideal for smooth takeoffs from a stop, and while I expect a slight improvement from the plenum change, I'm thinking if I can slow the rate of vacuum advance "retarding" at throttle tip-in when taking off from a start, this might allow a bit more engine torque during this transition. I'm going to experiment with putting an orifice/restriction in the vacuum advance hose to slow the rate of air flow into the vacuum canister when the manifold pressure increases at tip-in.
I have no idea if this would be significant enough to notice, but it won't cost anything but my time to try it.
Well, no engine street-driveability update yet, but the engine ran great at the track day Sunday. No higher RPM power loss noticed with the plenum divider back in the manifold. I didn't expect to see much of a difference as I recently learned from a David Vizard video that the divider elimination is/was an old way of making up for (bandaiding) an insufficient flow-capable carburetor. (I wish I had learned that a couple years earlier before I wasted time and effort cutting the divider out and then welding the damn thing back in recently.) My modest displacement big block seems to be quite content with the present 850 Holley on it. And just for amusement, I plan on making a pressure drop measurement of the carb some time soon just so I have actual data to support or correct my buttometer readings.
