Hyd Roller Dist Gear
SmokinBBC
Oak Ridge, NC
Here is what a bronze gear looks like after about 2k miles on the street. The cam doesn't have the pressed on gear.
Notice the wear is the same on the top and bottom and even on the gear blades. The blades are so worn "sharp" like a knife.
That gear looks like you'll be walking soon.
There has to be a better way- I've seen loads of pics like this. Bronze and fiber wear like crazy, standard gears eat the cam, got to be a way around this without having to get a gear made from unobtainium
I can't see the picture.
The thing is. All these guys think they need 80 psi of oil pressure hot. That takes probably double digit horsepower and that gear is just too small and soft for that kind of torque.
What does the cam gear look like?
That gear casued all kinds of problems from timing, to vacuum signal to funky oil pressure readings.
I talked to the cam grinder and he said that my best bet at this time is the composite gear. He said he has had good luck with them. He only uses the pressed on gears on his roller cams now.
I dropped in the composite version a couple of days ago. Funny how all kinds of problems go away when the cam gear is new:crylol: I'll have to keep an eye on it.
$110 bucks for the gear:censored:
I get about 60psi hot running and about 20psi idling. The cam gear looks ok....what I can see of it through the dist hole.
Peak torque is above 530ftlbs....and yes, the BB will put a lot of stress on that gear.
Ol' Red has a factory cam, the factory dizzy gear and both were perfect- the problem was the lower bushing in the original dizzy. Worn like a football- sloppy as it could be. It was loose enough it's a wonder the dizzy gear even made contact with the cam. BB thing I guess. 80 PSI cold and 50 hot. The ZL-1 oil pump has the longer gears and really puts a load on the whole thing. But never an oil related problem either.
Guess I been lucky, been running stock shit all my life, a few aftermarket cams, but I always ask/demand they be compatible with stock dizzy gears....
I have used and reused the stock stuff so many times, from cam to cam, engine to engine, and never an issue.....
I"d revert to a junkyard source if necessary, and use that....70 bux for a freeking GEAR?? THAT is unobtanium....
:hissyfit::hunter::club:
gear
I have a Lunati Voodoo hydraulic roller. I believe it's a billet cam with a pressed on gear. I know...it's been a while since the dyno. What gears should I not use on my distributor. Now you guys have me thinking.
If you have the pressed on iron gear on the cam then you use the stock iron gear on your dist.
I stay with oem stuff too, but if you have aftermarket it would be wise to use the exact gear the cam manufacturer supplies for that cam.
It's a shame they don't make these gears like diff ring and pinion sets, virtually last forever.
Some has to do with the new oil formulation too and putting an oiling slot in the dist body to spray the gears certainly won't hurt.
Here's a brief primer from an MSD engineer.
Look at the effort that goes into a ring-and-pinion installation, yet no one thinks twice about the distributor gear/cam gear relationship unless performance starts to suffer.
Distributor gears are designed to be sacrificial. They’re easier to replace than cam gears, so they’re engineered to go first in the event of failure. Properly chosen, your distributor gear and cam gear will differ in hardness. But since a flat-tappet cam is made to a different hardness than a roller cam, you have to do your homework and pick a compatible distributor gear. We spoke with MSD engineer John Clark to get the lowdown on distributor gear science. Properly set up, these gears will give you one less thing to worry about.
Gear Science
Stock flat-tappet cammed engines usually use a ductile iron distributor gear. A standard iron gear usually works well with a flat-tappet cam grind, but remember that stock gears were designed around a stock cam. Because most modern performance flat-tappet cams are ground on better quality (harder) cores, MSD’s iron distributor gears are surface-hardened a few points higher than stock.
Softer bronze gears are typically used when running a billet steel roller cam, because the roller cam cores aren’t as hard as those on flat tappet cams. Bronze gears have a bad rap for wearing very quickly, but that’s in part due to inferior yellow-brass gears sold by some companies. Quality nickel/bronze alloy gears like MSD’s are made from a tough alloy, so they should live for years provided you don’t beat on the motor before the oil’s hot. Sometimes your first bronze gear may wear out quickly as it massages the cam gear. John mentioned that if the cam gear is poorly made, the first bronze gear may destroy itself deburring and reshaping the cam gear, but the second bronze gear should wear in faster, work more smoothly, and live longer. Bronze gears wear more predictably since they’re the same hardness all the way through, whereas iron gears are only hardened on their outer layer (0.0005- to 0.0015-inch deep). Remember to check ignition timing; as the distributor gear wears, the timing will retard.
Ford developed mild steel distributor gears for use with factory hydraulic-roller-cammed engines. This steel is softer than the ductile iron gears, but harder than bronze, designed for longer life necessary on a factory engine. Relatively harder Chevy hydraulic rollers use a standard iron distributor gear, but at the expense of shortened gear life. The Ford gears, though, are pretty tricky to install since they’re both press-fit and pinned to the shaft.
The metal’s only part of the story, though. How the distributor and cam gears mesh is just as important. The pitch diameter is a measurement of how closely the cam gear and distributor gear mesh. Excessive clearance between the gear teeth shouldn’t be fixed by shoving the distributor farther into the hole; this screws up the proper wear pattern. The right way to take care of excessive backlash is with an oversized distributor gear. Currently, there’s no practical tool for measuring pitch diameter, but John told us a 0.006-inch oversize works great in 99 percent of small-block and big-block Chevys. For the “other guys,” MSD is working on a tool to correctly measure pitch diameter so a proper oversize gear can be chosen.
Autotronic Controls (MSD)
1490 Henry Brennan Dr
El Paso
TX 79936
I've been running whatever is steel MSD with my roller cam for 6 years, never an issue. Flat tappet fuel pump pushrod too.
I think people worry too much.
I only use steel cams w/ pressed on gears. Tried all th rest, nothing works as good as this, and like turtle says..no need to make stupid high oil pressure, esp. at idle
I never saw any problems with any decent aftermarket cam I ever used on the dizzy wear, or much of anything else either....let alone stock, the dizzy driver have NEVER caused much thought EVER.....
maybe I just lucky...I slap the dizzys back in and good for go....even with new/used cams and whatever dizzy was for the moment.....years later, fine....
:clap::goodevil::twitch:
