the Richmond 5 speed is 1:1 in 5th... the ROD has a bunch of OD ratios available for 6th from .91 to .52 and .when ordered my transmission from Richmond... talking to their tech support they wouldn't warranty the ROD behind the 502 Ramjet with out using the special 9 DP road race ratios K=.80 or L=.84.
never seen torque ratings on ROD6 I'm sure they exist. I know the Street 5 speed is rated at 450 in the lower gears but it drops off in the higher gears... I haven't been able to break it... my ROD6 and 3.08 Rear has held up well with annual fluid replacements...
I did snap my front differential mount off... built a new stronger one, more pinion down angle, urethane mounts instead of the stock rubber and added traction bars to take some of the load off.... didn't break at the drag strip... didn't break auto crossing... broke on an interstate in OD rolling on the throttle up a hill... BANG...
dunno about Gale Banks' vette... Id bet while the body was "stock" the body itself was tilted nose down about 2-3 degrees on the body mounts...
Chassis was lowered and there was prolly 2 rolls of duct tape sealing the thing up....
lotsa 700 HP c3's in the 200 zone... agreed not stock body'd.. If you look at the math the Coefficient of Drag is really important... IIRC a stock C3 is around 0.44, a C4 is around 0.33 and my ancient E55 AMG SEDAN (takes less than 30 seconds to bang into the Speed limiter at 168MPH from a dead stop) is around 0.28...
a good article...
http://www.hotrod.com/techarticles/body/hdrp_0609_aero_tricks_tips/
Anywho... depends on what you wanna do with the car.... 10 or 11 to 1 overall makes a great street-able 1st... space the rest of the gears to match the power charterisitcs of the motor.. my advice is do the math... simulation is much less costly than experimentation In this case...
:thumbs::thumbs:
