Yesterday's track day went well. Nothing broke or got scratched up. A few conclusions I came to during the day:
1) I need to brake later. I'm still trying to get accustomed to how much quicker the car decelerates with the decreased weight.
2) The car is very neutral through the corners, with a touch of oversteer when I ask for it.
3) I'd like more front grip. I can't find many more ways to pull weight off the car, so I may have to look for other methods (stickier tires, steering geometry changes, etc). I'll be starting another thread regarding Ackerman geometries pluses and minuses. I can move the steering rack position pretty easily, but I don't have a sure way to decide which position is best for my situation.
4) And finally aerodynamics. I'm getting down the straights quicker than before, the car feels steady, and the brakes and engine are apparently cooling sufficiently in the process. A problem I ran into repeatedly was the headlights popping up at about 120. I don't have the vacuum system re-hooked up after I pulled out the vacuum tank, so I had to manually close the lights after each session. I don't know if the problem is purely aero pressure getting under the headlights (or maybe entering the headlight opening gap behind the front bumper), or if it's a combination of that and no vacuum in the actuators to help keep the headlights down. I welcome input or suggestions about this issue, as my plans at the moment are to reconnect the vacuum lines and perhaps install a small plastic vacuum canister to compensate for small vacuum leaks in the system.
