Drilled and slotted rotors
MYBAD79
Moderator
City & State/Province
sunny Florida
Nothing I have to do right now but I found a great deal on rear rotors made by Stillen... $70 for the pair "on sale" .... too bad the matching front rotors are $320 for the pair.... (www.stillen.com and on Ebay)
Now.... Summit has drilled/slotted rotors with natural finish and PowerSlot rotors with a nice golden plating.... looks like no matter what brand, the natural finish is like $320 for the set and coated is $400-$420....
I really like the look but the look alone is not worth $400.... I have drilled rotors on my C6 and the breaks are great... has anyone direct experience with these rotors on a C3 ?
Didn't use that brand but I did put D/S rotors on my C4. Couldn't tell any difference performance wise.
I sort of expected that... maybe there's a noticeable improvement if you autoX the car... in which case you'd be seriously looking at aftermarket brakes anyways....
The rears for $120 shipped is a sweet deal.... would look silly with the stock front rotors though... :crap:
The holes are cosmetic. If your pads outgas so much that they need holes to vent, you have a pad problem.
No they are not. The offset is different between the fronts and the rears, it's not just the extra holes for the parking brake adjuster.
That was the first thing I thought about...... I had a good look at my rotors and had to scrap that idea....
I thought the offset looked different, at least from what I could tell from laying under the car.....then I thought about the inner diameter (emergency brake) and scrapped the idea.... how do yours fit ???
The difference is pretty small, forgot how much exactly. To the naked eye the rotors look identical apart from the adjustment holes. The fronts even have the "drum" part in them for parking brake shoes.
I never even noticed the difference by sight or feel
Although the hydraboost masks the feel of the brakes pretty well
Well, I "thought" they look different... hard to say with the wheels on and the car on the ground, not jacked up or anything.... thought about the parking brake and that was it....
If the offset really is that small it will fit but the rotor is not centered between the two caliper halves. Two pistons too far in the hole, the other two too far out.... Once you add pad wear you might pop two pistons out of the bore.... not ??
if the offset brings the hat inboard, washers could be used between the caliper and mounting bracket to re-center the rotor.
are those gold cad plated.? This is tempting. Shipping is $40 per pair for me though.
One rotor is 20lbs - shipping is not cheap but not ridiculous like many other Ebay sellers....
These are golden plated, all four rotors are $140 plus $80-$90 shipping... say $230....
The Powerstops from jegs are $320 plus handling.... $100 difference.... yes, it's tempting....
I have some old C3 rotors off my car laying around, I'll measure:
They both (front and back) measure 1.85 from the rotor surface to the top of the hat.
What about the other side? From the inboard rotor surface down to the inside of the hat ?
Is the diameter 11 1/2" or 11 3/4" ? I've seen both dimensions browsing the web and catalogs....
Both are 2.80
Both are 11.75 dia.
$220 for the set of four shipped......
SO CAL members: they're in CostaMesa and offer free customer pickup.... $138 for the set..... (Bird, that's in your neighborhood...need rotors ??)
Hey we could have Bird pick them up for us and ship them to us for free :quote:
I checked USPS: their domestic flat rate box is 12x12x6, 13.50 regardless of weight (per their website) .... if you can fit two rotors in this box shipping would be $27 for the set... I'm sure they come up with some stupid fine print if you show up with two 40lbs flat rate boxes at the post office :footmouth:
That is a great value. Just want to confirm: these fit om the front ?
I just replaced all four calipers but still use the old rotors.
i found drilled and slotted zinc coated ones on ebay for a little cheaper by the time you consider shipping. Is that gold colored plating superior?
Not really. :)
I'm sure the plating holds up better than paint, at least where the pads don't rub it off... for $10 difference I'd take the plated rotors ... now YOU might be better off with the non-plated rotors so they rust quickly and match the rest of your car :toothbrush::toothbrush:
You guys misundersand me. I don't want important pieces of the car to rust. Just valve covers, air cleaner, m/c and accessories. You know.... the **** everyone else spends their time polishing, painting and Q-Tipping.
The difference is 0.1 inch. This is enough to gouge the inner surface on the front and outer surface of the rear rotors with stock calipers.
Want to see the pics?
Just order 4 rears
They are all the same
I ordered 4 rears per your advice kid. I'm thinking they will fit in spite of the .080 offset difference.
I understand why they were on sale. When i opened box 2 of 2 they looked just a little corroded. Not suitable for the show n' shine crowd.
