damoroso
Okay, it's stupid hot and humid here, and I decied to do the front suspension on my 81. I was tired of fighting to get the coil springs back in so I sat back and came up with a different approach that works really well, is safe and easy. I was so surprised by how easy it was, I did it about a half dozen times to make sure I just didn't get lucky the first time!!
You'll need a standard coil spring compressor (not the kind for struts), a floor jack, piece of wood (for protecting that new finish!) and a good kick!
Start with the control arms in place:
You'll use the spring compressor with only the threaded rod and threaded set of hooks:
Pull the hooks off and drop the threaded rod through the upper shock mount hole at the top of the spring pocket on the frame:
Thread the hooks on the rod, you'll be pulling the spring towards the frame pocket:
Slide the spring over the compressor, making sure the wider spaced coils are at the top and the spring is in position to fit into the lower CA spring pocket. The positioning will be obvious if you look into the pocket of the lower CA..
Now snug up the spring compressor. It won't take much, and you don't want to much tension on the spring, you don't need it. If you put too much tension in the spring it'll be harder to get in place. Once you get tension on the spring, lift the lower CA just enough to touch the spring. You can see in the pic, the spring isn't compressed much and the arm wasn't brought up much.
Push the spring into place as best you can, sit back and give it a good kick!
Once it's in place, lift the control arm with the jack and bolt the steering knuckle into place. Then release the tension on the spring compressor, removing the threaded rod. Drop the hooks through the bottom of the control arm, and there you have it, coil spring in place!
