- Joined
- Mar 30, 2008
- Messages
- 3,080
- Reaction score
- 42
- City & State/Province
- Clinging to my guns and religion in KCMO.
Was doing some suspension tweaking work on the '69 when my attention deficit disorder kicked in (self diagnosis). I noticed some spare C4 brake parts (plastic booster and master cylinder) in a box, and started thinking about things. I like how light the C4 boosters are (about 4.5# lighter than a C3 booster), but the master cylinder bore is awfully small. I measured the diameter of the booster, and it was appreciably larger than the C3 booster (about an inch and 5/8 bigger), so that wasn't going to package very well. I looked at my '84 and noticed that the booster on it was different (in appearance, and it was metal), and made a measurement of the diameter. It was smaller, within about a quarter inch of the C3 booster. Hey, that might package okay. But what about my present (C5) master cylinder? I tried a spare C5 m/c, and it looks like it would bolt up to the (plastic) C4 booster with a touch of ovaling of the m/c attachment holes (hopefully the early C4 boosters are identical in the attachment area pilot hole).
The booster mounts (to the firewall) are different (two studs versus four on a C3), bit the C4 booster is about two inches shorter, so that leaves plenty of room to make an aluminum adapter to change the bolt pattern.
I'm just looking for opinions here. It sounds like a PITA to change the booster, but I'm kicking around rebuilding the pedal assembly eventually, so while I'm in there I might just as well change the booster, and also install the lighter weight stamped steel pedal hanger. It could be another 8-9 pounds of weight reduction (total) combined into the one painful R&R.
Thoughts?
Thoughts?
