MYBAD79
Moderator
Lookin' good! Do you call that construction method a "Lean-To"?
Cheers Jim
Karsten, I hope that double wide patio door and side window thing is made out of plastic, and by that I mean NO WOOD......otherwise they WILL rot in the Florida rains/humidity......the only thing you can do to stop that will be put up a gutter so the roof water not soak it too bad, and keep it finished, it only took two years for the water to win against the new metal door I put on my room addition down here, the damn frame was wood, not plastic, so rotted out about 4-6" high on each side, filled in now, and that white vinyl corrogated vinyl roofing extended out about 12' or so, keeps the water off.....that and the slab it's over is now cool enough to put a hammock for the nice daze.....:surrender::smash::thumbs:
The old door was metal and some wood..... The wood rotted, the metal rusted.....
This one is fiberglass so I should be good for a while![]()
What is the roof trusts made of in FL? With the walls and slab cement I was wondering what holds the roof up?
Good, still put up a rain gutter, if nothing else it makes using the door much more pleasant in a rainstorm.....
In modern constructed houses you have so called "hurricane straps" securing the roof trusses to the walls. .
An interesting note, I talked to an insurance adjuster a while back and he told me that after the tornado that hit a neighboring city a few years ago, they found that the newer houses with hurricane clips attaching the roof trusses to the walls suffered more damage because when the roof lifted it tried to take the walls with it and destroyed everything. But the older houses built with only 3) #8 nails toenailed holding the trusses fared better because the roof just pulled off and left the walls intact.
"Just sayin..."
Over here, in the tropics the roof trusts are steel and either corrugated cement or ceramic tiles. Very little wood as the dampness and bugs will take a toll.:sos:
Update after a few months: got the kitchen almost done ....
I have that stacked stone on my fireplace.love it. I was going to do my kitchen backslash with it but thought keeping it clean would be a chore.:waxer:
Nice. I like the stacked stone on the island. What product did you use?
I want to use something similar in my kitchen but I need gray tones.
DC
Kitchen tile has to be baked hard TILE, either flat or slick finish, anything else will not do well.......old kitchen installer here....:drink:
