Hey guys! I thought I would start this and update it as I go. Tonight I got the crank installed. I will keep updating this with pics as I go.
This pic shows how I polished and profiled the oil passage from the pump. Thanks for the tip Twin Turbo!!!:thumbs:
All surfaces were cleaned with brake clean prior to bearing install
Liberal use of assembly lube on the bearing face.
Crank was thorouly cleaned and carfully set in place.
This shows the rear main seal and th use of gasket maker on the edges. Thanks TimAT for the instruction!:thumbs:
Crank installed and torqued to 110ftlbs. I torqued in increments of 50,75,110 spinning crank in between each. Crank spins nice and free by hand!!!:thumbs:
This just shows the rear cap and the gasket maker oozed out. I did clean this up a bit. DO NOT USE RTV!
Next step Piston install!!!
:thumbs:
Wade
:thumbs:
Wade
