1958 MGA Coupe
well last time I bought the wire I did get the biggest spool I could...
now to move to the inside
and look what I found inside when I opened it up.
they mice must have been nesting in the head liner
I would never ignore you guys
well finally got a chance to do 3hrs of work
fill the weld areas
sand the body panels
finally got out the real spray gun and primer, the shiny metal gets self etching primer first
and these are the contoured sanding blocks
yes your are right one of the guys who has coupe cut off the inner fenders welded the fenders to the shroud and stuffed in a SBC with a blower its awesome
but this is just going back to mostly original form
another 3 hours......from this point in it will be working on about a 2' x 2' section at a time. this is really good because once its in primer/surface coat you can see where you need spend your time and you can be very focused. so I will do body work for about 30 mins each night. not enough to get bored but just enough time to move the project forward.
it will be Red out side with a grey leather interior and grey carpeting. the color is coded into the VIN so on this project its staying pretty true to original form. not 100% correct but as close as I can get without killing my self or spending any silly money.
that quarter scuttle that the steering wheel is hanging on is the test color with out the final color sanding or clear coat
my wife has been watching the two grand children while the kids are at work, and it turns out that what we use to do easily like grocery shopping, cleaning, yard work etc now has taken on a whole different dimension and it has encroached upon my shop time.....oh well we will just have to adjust
lets take care of some areas
sand with a long board file
use the black primer as guide coat
any shiny metal gets self etching primer the final sanding will be done by hand
lets take on the 800 lb gorilla in the room.....if its not right just re do it. after all its just metal
see the crown on the near side
no balls no glory
SBC main cap
nice and tight
cool it off after the weld with compressed air
well the creative juices were flowing this am fueled by a gift of a fork lift extender.....along with two pieces of a snow plow picked up off the road over the years, the base weighs about 125. all together about 210 lbs. the bead roller is bolted so it can still be used in the vise and the planishing hammer can get mounted on the stand also
the base 5/8" x 6 x 24" doubled up to 12"
and it works as planned
That BiG angle iron is from at least 10 yrs ago, the 5/8 x 6 snow plow blade is last winter and the bent fork lift extension is fresh
a quick 2 hrs today..... the goal this weekend is to finish all the body work.
any exposed metal gets green se;f etching primer
I worked some more on the front fenders today and the bonnet, tomorrow the doors and the front shroud where I recut it.....then everything should be ready for block sanding to a nice surface for painting.
no, its a fun car, my DD
worked for a little while on the MGA and then helped MGA Charlie with his beautiful TF fenders.
those TF fenders are beautiful
my TF when I had hair ....
there was one spot that when the fender was all bolted up just didn't look right, it had some of a crown to it.....so its time to address it, I am not looking for perfection in the body work but if you can see something that's not right then you need to fix it.
the crown is hard to see but is in the first 2" of the seam and is from welding I think I didn't grind it down enough at first
so grind it down, it must have been from one of the first welding tacks when I was repairing it
just a quick rough sanding to see if I got it right
