SuperBuickGuy
I wish there was an easy way to put the carb on it for now.... but in-tank pump has way too much pressure
Add a return line and a fuel regulator. What pressure is required? I'd have theh same problem when I (finally) get the Weber Carbs on top. The old school solution - return line and regulator. The Webers have to be down to 4 psi. Well under an in-tank pump.
Just a quick thought - but may involve a bit of effort - and get you running.
Best of luck - the carbs would "bypas" the EFI problems. Suppose you'd leave the injectors in place?
the injectors are inside the throttle body.... and on their way to California.
My biggest concern is whether or not I can get the pressure low enough not to lift the needle off the seat in the carb.... the pump, iirc, is 60 psi .... even with a bypass regulator, I'm not sure it would work.
