BangkokDean
Does anyone have a wiring diagram for a L98 TPI system they can post?
			Speed density or maf?
What is the difference?
	OK can you tell which one I have here by the pictures?
More importantly, what ECU do you have? One with 2 or one with 3 plugs? A Speed Density ECU has 3, a yellow one for air bags is added.
How did you plug the hole in the runner for the cold start injector? Have you also considered using a 7727 ecm that you can mount under the hood ?
I dunno Jeff, heat is the enemy of electronics, I just as soon have it in the pass compartment.....much less it's not getting wet.....
no matter what the factory does....:hissyfit:
AUJP = a 5.7L L98 Auto prom, that's a speed density setup.
You do know you will have to get a bin with VATS disabled right?
I should have the ARAP bin somewhere. Would be best to tweak the bin for the correct axle ratio too. What kind of injectors? Looks like painted multecs? I would change them right now, easiest to do with the engine out of the car. Get some modified Bosch IIIs from southbay. They are a day and night difference with those junk Multecs.
I am just wondering if someone could provide an English translation?
I bought the motor with the set up that should be all ready to run. It came with the sensors and new wiring loom. The injectors are Accel 23lb. This motor will be a DD so I was not looking for something to go racing. The engine builder sells these setups for mostly street rods and they are sold ready to run, What I need now it a wiring diagram in order to connect all the sensors correctly.
Maybe later after getting into this I will understand more than I currently do, which is very little.
The sensor wires are made so they only fit one sensor. it's easy to hookup TPI.
