This Holley is going to be the death of me. Or at least my engine
clutchdust
Millionaire Playboy
In transition
I've been working on getting this stinking 750vs Holley sorted out for several months now. I finally got it pretty well dialed in, or so I thought. I still have (had) a very slight flat spot on light throttle tip in but it was something I could deal with for the time being. So overall, I was fairly happy with this boat anchor.
Flash forward to yesterday, I had to go to my chemotherapy appointment so I hop in the car and off I go. Now the car has almost no acceleration on tip in. In fact, it sounds distinctly like a "Jake Brake". I still have the original narrow band O2 sensor hooked up to an LED A/F gauge. This thing is showing super lean all of a sudden, as in not even lighting up the lean LEDs. I can't remember exactly but I think the range is something like 10:1 on the rich side down to 14.5:1 on the lean. Something like that. So now I have to yank this goddamned thing off again and find out why I have no fuel on the primary side.
The silver lining is I know my secondary side is working just fine because I can see on the gauge when the secondaries open as the A/F reading instantly goes a little fat and the car runs great for the few seconds I'm into them.
40 miles round trip. Hope I didn't bang any pistons.
Fair sails and following seas to you man....:gurney:
HOLLEY, man, I had to edit my post....I obviously didn't read your post close enough....sorry...
Take care man....
:drink::drink:
Well, the good news is it was a very simple problem. I just hope I didn't do any damage driving it. Turns out that months ago when I changed the float level and ended up changing out the needle and seat, well long story. In the end I cut the old o-ring (since in the 50+ years Holley's been making these things they've never found time to put a small chamfer in that seat) and a piece of that has been floating around for who knows how long. I had the bowl off and thought I douched it pretty well with carb cleaner but that little bastard bit of o-ring must have been hiding up behind the needle and seat. I pulled the bowl off and there in all its glory was this small piece of o-ring blocking the left side primary jet. No wonder it felt like it was Jake Braking. Took it out, douched everything down again with carb cleaner and took it for a spin. Amazing how much better the car runs when it gets gas!
