I would ditch the block and go with a later '88 up block.....I have a '89 truck factory 4 bolt block in mine...all the improved rear seal, and the block is already machined for factory rollers...
the top of the lifter bores is cut flat for the dawgbone to fit over, that keeps the lifters from twisting of course, and the spider has to be a custom/aftermarket to fit the newly machined bosses in the early blocks....
IMO, I would NEVER use any toggle type lifters, I have heard too many stories over the years about them letting go in street/wear use....race only item apparently....
I suspect the GM engine folks knew a trick or two....never heard of a factory lifter failing due to twisting in the bore........
either way, with the block swap, or cutting your present block, you out some machine work...if you want rollers in there....
:surrender::thumbs:
Oh, edit, factory rollers are taller, so the pushrods are shorter too....don't forget that.....
