Solid roller lifters ISKY 1241LSH or Comp Cams 818-16?
Imo Apita
Given the assumption that the price is the same which roller lifters would you buy and why?
Anyone of them better then the other?
Does either one require any special valve train components or machining?
Intended use is a .030 over bored '74 010 SBC block for a solid roller cam 383 stroker.
New the Iskys are $600+ and the Comps $390.
Can get either set used.
Choices, choices...........
Can't find a lot of feedback on the ISKY's on the net.
You can probably find feed-back on Isky's on SpeedTalk.com ISKY's are HIGHLY thought of.
Jake
Thanks JAKE, decided to go with something else, just bought a set of Crane Hi-Energy SBC 1.5 3/8 Stud Roller Rockers.
