Actually there is, the access there is good enough to weld a nut on and use that as a fresh head, the heat will get the bolts loose too. Also, you could always remove the bolts from the door and then work on the hinges with the door removed.
I like this idea, the welding heat may help loosen the seized threads, but find a long coupling nut to weld on to your seized bolt. The long coupling nut will give you enough material to weld on, with enough nut left to easily fit a socket.
I do this all the time and never use a long coupling nut. Just oversize the nut and weld the center of the the nut like you were doing a plug weld.
