chevy69
They go through a bunch of aftermarket kits, installs, etc...
Cliff notes??![]()
I agree with all posts on this one, it is a nice write up and they are way over priced. I still can't justify 2k to ??k on a new injections set up. The mass-flow setup seems interesting since you don't have to tune it. But at 3k, I could buy a new crate motor with a carb.
True, you probably could. But then what? Do you have a old Ford pickup that needs an engine?
....:stirpot: Just pullin your chain, don't go high rail. We have discussed the pros and cons of EFI vs Carbs around here till we are ready to :suicide: You either understand the benefits or you don't. Your money spend it as you wish. :drink:
Bullshark
For $3000 you can buy a LS1 with accessories... incl computer.... a LT1 is a lot less and probably the best value for the money spent, definitely a better value than $2500 for a aftermarket FI kit....
Pick whatever engine you want. Install your favorite intake / TB, fuel rails, injectors,sensors, used, new or whatever your pocket book allows. Just save $1K for a good afermarket ECU,wire harness, and wideband O2 setup. You will be glad you did.
what's wrong with the stock computer? The LS1 runs pretty good with the stock stuff.
I don't get it: why would you buy an aftermarket ecu and wiring if you can get all the GM stuff incl. fuel rails, injectors, computer and so on ? Can't get any easier than that ??? Am I missing something ??
The LS1 engines including everything sell for $3000 or even less....
Gene - you were somewhat of a pioneer if you took this path 15 years ago. The wiring scared many away but you went for it. My hat is off to you, but a lot of guys are scared of wires :hi:
There is a very good thread on thirdgen.org about using a LS1 ECU on a gen1 sbc. Seems like a good cheap alternative execpt for the $800 software to tune it. That seems to be where most of the expence come in any efi system and the main reason I am planning on going with MS this winter.
If someone can find some cheap software that would allow for reprograming and tuning a newer GM ECU then we would be set.
Makes me wonder if a LS engine would run and do as well with the older simpler computer, and just one or maybe two O2 sensors....say like a LT1-4 engine series....
or would it loose a lot in performance, and especially I wonder the affects of loosing sequential and just going batch fire like my old shit....
:crutches::chinese:
