MYBAD79
Moderator
Any recommendations for carrier mounting bushing? Rubber or poly? Or aluminum? I saw over at CF somebody had a front mount on the frame break off and someone blamed the poly bushing. It looks like it is hard to even find rubber bushings for the rear mounts. This is for the '81 diff I just bought by the way.
i use poly for the front diff mount and this is the only location I am preferring poly (had some really bad experience with poly bushings and body mounts). you can cut the poly diff mount to change the driveshaft angle, had to do this after the TKO install....
OK. more questions. I'm thinking about going with the Global West TAs and struts. Mike Dyer says the GW TAs are a quality product. But I'm wondering how much if anything I will be sacrificing in ride quality. I don't autocross but would like nice tight handling for the mountain roads around here. But I don't want to rattle my teeth on every bump. So you guys with the johnny joints on your TAs and spherical ends on your struts; did it make you car ride lumber wagon or did it just improve your handling?
I only test drove the '79 for maybe 5 miles after my JohnnyJoint install, so far so good... I also have the spherical rod ends and the ride is not harsh
