Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
Have a prob w/ an MSD 6 Digital. Installed it, worked fine. After a couple of times starting the car it's now dead. The engine is new, tuning the EFI so it only idled a bit and was running for some short intervals.
The led light does not always come on with the ign. key in the on position. I thought it was an ign. switched 12V problem but it isn't, it's also not a ground prob. The 6 is wired directly to the battery, all wiring is brand new, even the battery cables and all ground cables on the engine, all heavy oversized copper cables. All connections are weatherpack and soldered.
If I unhook the neg. battery cable and then hook it back up and then turn the ign. on the led illuminates. When cranking it flashes but when turning the key off and back on again the led never comes back on unless I remove the neg. cable again. It's like some internal component needs to bleed off (capacitor) or it won't work. With led flashing there is no spark. I have it wired so that I have a "plug" that I can plug in place of the weartherpack to the ignition so that it completely bypasses the msd system (have been stranded before LOL) and bypassing it the car runs just fine.
I'm 99.9999% sure the digital 6 is dead but I am wondering how this is possible. What would cause these things to just die? I've had it happen before with a msd 6 and a crane box. Are these things just not durable enough? Either they last for a long time or they die soon after installing. I think the crane one lasted 5 minutes. It was an older blue one, have used 3 of the black ones and never had a prob again.
