69427
I'm striking out finding some suitable length rear spring bolts for my hybrid application. With the combination of C3 batwing and C4 spring, I need an extra long set of bolts.
I need roughly 13 inch bolts, with 12 inches from the ends of each cushion washer. So far I haven't found any sources that sell bolts longer than 10 inches. Anybody know of any decent sources?
For the short term I could cut and extend the bolt lengths by welding in some lengths of tubing (I would have to do some tensile strength calculations of the tubing before I decided to use this long term), or use a couple of coupler nuts to form the correct length bolts, but I'm not totally sold on the thread strength of those things.
I've been kicking around a couple ideas using a long top bolt, and a heim joint lower section to allow a bit of flexibility and adjustment, but I haven't had time to work out the details yet. If I just found some long bolts it would save me a bit of time right now.
