Stpman
I have the Miller 175 amp machine, The auto set came out a couple years after I bought mine. The settings inside the machine are spot on and I've rarely had to mess with the settings from there
			How useful would this be?
Miller Auto Set:
The The Millermatic 180 mig welder with Auto-Set offers all the benefits of the standard Millermatic 180, but adds Auto-Set to eliminate the guesswork. Use Auto-Set when you want the speed, convenience and confidence of pre-set controls. Simply set the wire diameter, set the material thickness, and go! The Auto-Set control automatically sets your welder to the proper parameters. It is available when welding mild steel with solid wire and only works with .024 and .030 solid wires and C25 shielding gas (75% Argon, 25% CO2).
When not within the Auto-Set profiles, use the manual mode to set the weld parameters you desire. The parameter door chart lists voltage and wire feed speed settings options.
That's interesting. Mine has a 30A for the 240V. It has two 20A for the 120V(each of those has 2 recepticles).
