FS: 4spd pedal conversion
redvetracr
midwestern USA
This is pretty much the whole deal out of a 75 Corvette but I`m pretty sure it will fit any C-3 68-82. Borg Warner Super T-10 2.64 1st gear (three rings) with shifter-yoke-90* speedo adapter and reverse switch, clutch & brake pedal assembly with the neutral safety switch, #621 bellhousing w/fork-trans bolts -rubber boot and inspection cover, flywheel-pressure plate-disc and bearing (like new), z-bar-both rods and the swivel, trans mount and block ball stud also...did I forget anything?? $1095+ shipping. send a PM if interested.
would you be willing to seperate? i may be interested in everything but the tranny, bellhousing and clutch..
