Carburated Nihilist
The only one who can be trusted is you, going round & round in whatever direction fits your zen until you are satisfied. I always have at least two quarts on hand, the (new) stuff that comes out I put in a different bottle to settle for a long time before I put it back in. With a dry, empty system, go get 3 or 4 quarts--don't crack cans any unless you need to, but have them ready in case.
Don't mess with "speed bleeders" & vacuum sucking---this just introduces air at the bleeder threads, which is still air in the fluid. "In my experience". Maybe a speed bleeder with pressure feed would work, I dunno, I don't have a pressure bleeder. I got a midnite fabbed spring loaded shaft & tube with a handle which I pull back and jam between the seat & brake pedal while I go work the bleed screws. Takes a while, but whatcha gonna do at midnite with no cooperative helper?
If it's been empty, after you're done, let it set a while, a day or two at least. Smack what you can with a hammer--tap lines where you can, smack rotors, to consolidate air bubbles.
Then bleed it again. Until you feel good about it.
Thanks for the smack/bleed twice advice, that makes a lot of sense.
I realize I can get a helping hand (foot) easily (Ms Denpo?), I think I'm gonna stick to the old fashion method after all.
I'm planning to put dot 3/4, problem is when I reinstalled the calipers I was still planning on dot 5, so I rubbed the piston with dot 5. Would a tiny amount of dot 5 mess a dot 3 system? Do I need to take down the caliper to wipe piston clean?
