SUPERPOWERS
New member
- Joined
- Mar 29, 2008
- Messages
- 3
- Reaction score
- 0
57861]
these are in the prototype stage and will be available soon. And every one of you will be able to afford them. :bounce:
yea but can you afford to sell them?
you are god damn right I can! AND WILL!
Chinese stuff is looking better, definitely cheap enough. :nuts:
This outfit labels for anybody, guess they are going to broaden their market to C3's.
Unbelievable how cheap they can make these.
alright you ass clown, WTF is your problem??
These are not and I repeat NOT MADE IN CHINA!. they are designed and fabricated right here in the USA.
Do you have a problem with everyone getting a good deal on a quality product? I personally have these and the sidepipes (big block and small block) and the C6 system in my possession and I would have no problem putting them on my $60,000 Custom C3 vette!
I had a feeling they were chinese
NOPE!
the reason is those weld beads look like typical beads done for looks. Now, they look good but the bead buildup and litle overlap between the drops is typical. They do this becaused welding like that prevents full penetration and the need for backing gas, if you do have full penetration without backing gas you'll get a rough texture on the inside and the weld will turn gray instead pf the nice and shiny look they now have.
As for the pipes being hay/brown, they will discolor all the way from heat if you run them.
Do the pipes neck down or is it a sort of starter cone that transitions from sort of square to round?
any stainless steel is going to turn color after you run them. I have a $2000 Kooks system on a 2010 Camaro and the sob's turned color!
the pipes do not neck down and they are not stepped. The flange has rectangle or more commonly known as square port so the round pipe is squared at the end like you stated. For those that don't know, this is done so that you can access the mounting bolt holes. Otherwise you would have to use the head plates and thus the price would increase and you are back to Stahl.
:hissyfit: Course then again, why couldn't someone test fit the things, then get a good welder to go over it all again, make damn sure it's kosher....
:hunter:
they are in fact kosher.
