mike76c3
1976 L48 odometer reads 70K+ (not sure if it rolled over)
- Edlebrock Performer intake
- new distributor/cap, plugs, EGR, carb rebuild by SMI, all in 2016, 3K mi. since
- not sure most recent oil change, think it was 3/2018
- mostly highway miles, 3K MSL give or take (high desert), usually 16mpg
- needs about 1/2 qt oil approx. 1.5K mi.
First test 7/2018, ambient temps low 90's, humidity pretty low
Found #1 plug wire arcing to exhaust manifold, #6 boot crumbled,
so replaced all plug wires. Checked new wires' resistance, was
within specs (but didn't record values).
Second test 12/2018, ambient temps low 60's, humidity pretty low
Not sure what to make of the low HC at 25MPH, especially the second test. Tried to understand what all the gas values mean, but didn't have much luck (all the sites that came up seemed to be quoting from the same source). All the lambda calculators I could find seemed to require an entry for NOx, which apparently CA doesn't test for anymore.
Thinking the high HC value meant some kind of ignition failure, I pulled the distributor cap. Looked good (minimal pitting). I pulled the plugs; didn't find any that were wet (car's in garage, haven't been able to get doors open, so couldn't do procedure to properly read the plugs). #8 had some whiteish/light tan deposits. Pulled the EGR; both it and the intake manifold looked O.K. (failed a previous test because original manifold was plugged and EGR was bad).
Once I can get the garage open I will try to check the EGR, read the plugs, and do a compression test.
In the meantime, based upon the smog test results, any advice on what to target?
Thanks,
Mike
Thanks,
Mike
