Epoxy products
gkz
Wake Forest, NC
Much talk lately of SMC, poly resins, glass products, etc; this is what I use. Some of my co-workers build boats and swear by this stuff. Myself, I figure if it can withstand salt water, UV, pounding of the waves, hot, cold, hurricanes, etc; it should be cake walk for a vette. The 403 filler you mix w/resin to get the thickness you want as an adhesive. The 410 you mix for a bondo-type sanding filler. Once it's bonded, you better have a good chisel... (maybe I can fill the driveway crack)
