Twin_Turbo
Der Maulwurf
- Joined
- Mar 5, 2008
- Messages
- 7,575
- Reaction score
- 6
A while ago I installed a dynatech exhaust system under a CE C5. The system consists of stainless full length headers, a dual exhaust system w/ 2 cat cons. Also required are 2 wiring harnesses to reconnect the O2 sensors as the stock wiring will be too short. The air injection system bolt up (had to tweak the stock lines a little to mate up the little manifold on the end of the tube)
The only thing to watch out for is to make sure that all the wiring and such is plenty clear of the exhaust. Some boots for the plug boots are absolutely needed to keep them from burning.
The system is relatively easy to install, the instructions were excellent. It'll take some careful maneuvering to get the headers in place (after removing the coil packs and some other components) but it's very doable. it IS tight in there, there's not a lot of room in those engine bays at all.
The best part is the sound...oh man
it's LOUD. The mufflers are stainless borlas (not part of the kit) and the car now screams, especially @ WOT. It also pops nicely (loud) under engine braking and closed throttle rev down.
The parts quality is excellent with neatly welded components.
The ground clearance is excellent, everything tucks away nicely just like the factory exhaust.
[ame]http://video.google.nl/videoplay?docid=-3861166977841544844[/ame]
