Clutch Pedal Stop
Fuelie74
Monroe, WI
I need to make a pedal stop for my clutch pedal now that I am going to a hydraulic clutch. What are the rest of you doing for a pedal stop? Pictures would be great!
Here is what I used... If I kept my hydro clutch, I would have cut the head off of the carriage bolt and welded on some flat stock with rubber on it. This worked well though.
Here is another option... This is my fathers car- the pedal stop (not installed in this pic) is threaded onto the rod going into the master cylinder so that it bottoms the rod on the firewall. I think Ill try this method when/if I go back to a hydro clutch
I am finally getting back around to this and wondering how do you figure out the right spot to set a cluch stop?
