DWncchs
- Joined
- Aug 23, 2009
- Messages
- 341
Do you have to get every little bit of air out ? The top works beautifully except for 1 thing,the manual says to stop the top 15" from full down and pull the top material out from hinges before fully retracting,but the top wants to creep down while at 15". Do you guys think this creeping is a result of some air left in the cylinders or is it bleeding through the pump moving the fluid on the lower side of the cylinder piston to the top due to the weight of the top ?
I know I can just loosen the lines and bleed but it will be messy and I hate to do this if it won't help.
When I hooked these cylinders up I flipped flopped them to work air towards the pump reservoir before installing . The top cylinder line is where I see some air , I feel like air on that side won't effect the creeping in the 15" position. Thanks
