Carb Spacer and Heat Shield
gr8vet
I'd rather be in Bonaire
Most of you may know this, I did not know the right questions to ask, but, I finally found the answer. I had this issue with old engine and big time problem with the new engine. Fuel was boiling after even a short run, and continuing to flow into carb, talking about stinking up the basement.
1" Phenolic Spacer, then thanks to a friend that had an old heat reflector plate that fits under carb. VIOLA! What a difference, carb will idle even when super hot. NO more boiling fuel, no more horrible smell after shut down.
Thought I would share in case someone else may be having same issues.
Yeah, those 2 really make a huge difference. Some cars like the early Camaro w/ LB9 (?) H.O. (ahum) 305s even had a little fan from the factory to combat fuel boiling. They also added an in tank fuel pump to those
