big2bird
So what is the trick method to prepping the stock IRS to launch properly at the drags? Solid axle, not an option. I know people have done it. I need details.:drink:
1st question, what power levels? Are you referring to beefing up the IRS or are you talking about getting it to hook with respect to wheel hop, camber curve and so on?
But Monty never broke his, and that guy Motorhead on CF, I'm pretty sure he still has his Dana one also. Something must be keeping them together!
Hi Jeff,
The Dana 44 uses some parts comparable to the iron diff in strength. I can install a steel cap which fixes the weakest link. The other problem will be the size of the rear pinion bearing. It needs to be larger for abusive driving.
It really depends on how much power you're putting to it. 400 hp with an auto and street tires should hold up fine. 500 hp with a stick and slicks will probably snap the case in half. It may handle it but I doubt it.
Here's your choice:
stock dana 44
Dana 44 with steel cap
stock iron diff
Iron diff with steel caps and Toms 1350 axles
12 bolt with 1480 axles
and if money doesn't matter, Dana 60
As for traction a stiffer spring and stiff shocks. Anything to keep the back end from squatting. The more it squats the less downward force is applied to the tires. The body isn't really squatting. The trailing arms are being forced up into the body do to trailing arm angle.
Mike
Big Bird when you look at the rear suspension to limit how far it goes is right in front of you lol. The factory bump stop that hits the trailing arm to limit the uprward movement. What you can do is simple. Just take a 1" by 2" piece of square tube and put that between the bumper and the frame. If it does not allow it to move far enough you simply trim the rubber pad down the amount needed. You might even be able to go to your local High Performance shop and pick up some rear suspension bump stops instead of cutting the factory ones. That is if he has the stiff rear spring and good shocks to go along with it.
This simple trick has been around forever. But it took Jim 427HotRod to remind me of it lol.
BRB I will even take a pic for you lol.
I have not cut on the bump stop as of yet since it has not been on the ground.
I would like to add that a person should mount everything as solid as they can. I have the locating disc's as well as a solid disc to replace the rubber snubber.![]()
It will not or should not lock the trailing arms in place. There should be some movement. And yes when you launch it will hit the bump stops.
But what do you wish to do with the car? Are you going to drag race it only or is it going to be a street car. You have to decide on what you wish the car to do.
If you are going to just drag race it with the parts you have then yes you would remove the front sway bar and put in 90/10 shocks in the front and some 50/50 rear shocks. And the list goes on from there.
But I am not a dedicated drag racer. I like my car to handle on the street and yet have some get up and go. I am would guess to say I am looking for more of an over all car. It will do everything okay but not dedicated to one thing.
You have to decide on what you wish your car to do and then build to that.
