Here is some interesting facts that are little known
1966: First sheet-molded composite (SMC) used for front body panels and hood.
1970: Plenum and instrument panel support panels switch to SMC.
1971: Rear quarter and end panels switch to SMC.
1984: One-piece, lift-off SMC roof panels with massive rear glass introduced.
1993: Rear inner panels molded from recycled SMC, an industry first.
Most everyone seems to get hung up on this SMC stuff.
It really means very little.
What is important is that epoxy has a far, far more adhesive strength than any type of polyester or it's hybrids. Since all bonds (glueing and fillers) only have a mechanical bond, then this is the product that will adhere the best to any type of composite, bar none.
It's really just that simple.
Here is from the GM Repair Manual. Remember that they used the adhesive as a filler at the factory.
Description and Operation
Sheet Molded Compound (SMC) Panel
Bonding
This is intended to provide general guidelines for
sheet molded compound (SMC) and carbon fiber
adhesive bonding of full panel replacement in regards
to collision repair procedures.
Sectioning, partial panel of full panels, is not supported
by General Motors unless specifically documented
in a Service Bulletin or Manual.
Important:
• Prepare the surfaces to be bonded according to
adhesive manufacturer’s recommendations.
Many adhesive manufacturers have different
preparation methods. Do not intermix adhesive
manufacturers systems. Mixing materials
from different manufacturers can produce
unsatisfactory results.
• DO NOT top coat any adhesive bonding mating
surface. Use primer only on bonding surfaces.
Refer to adhesive manufacturer’s
recommendations for priming applications.
Adhesives currently meeting the performance
requirements include General Motors materials and
products manufactured by Ashland and Lord Fusor. At
this time, ONLY the adhesive products listed below
meet this guideline:
Sheet Molded Compound (SMC) Panel Bonding
Medium Set
GM Goodwrench® 89020330
GMSPO of Canada 8902332
Ashland Pliogrip Structure Adhesive 7770B
Lord Fusor Structural Adhesive Product Type 127 EZ
Fast Set
Ashland Pliogrip Structure Adhesive 7779B
