anyone know if my 90 corvette rims will fit on my 97 camaro?
JeffP1167
Yucaipa, CA.
I don't want the tires to get flat spots sitting so thought I would use them on my camaro for awhile.
my camaro wheels are 16x8 245/50/16 I'm more concered with are there offset differences and will rubbing be an issue.
I used to run the (C4) ZR1 wheels (17x11 with 315-35-17) on my '99 Camaro, no problems... the fronts were 17x9.5 with 275-40, again, no problems.
I would assume that if those monsters fit the Camaro then your (stock?) 90's rims and tires should fit with plenty of clearance.
Did your PCM wig out from the difference?
Mine has the 3.8/auto .... and were they rear disc brakes a issue?
