Vetteski
Member
I am autocrossing and I am needing a new clutch and I want to go to the lighter flywheel and clutch.  I have talked to Ram and McCloud tech guys and I wondered if any of you know more about it and or have done it.  My car weight is 3260lbs and I have the ZZ4 engine with the hp at 355 torq at 405.  My trans is the Richmond Super 5 speed with 2.89 first gear and 3.70 rear gears for a total of 10.963 for the first gear. I understand the lighter flywheel removes the weight that helps you start the car rolling but then really helps your car in the braking and accellerating out of a turn.  My question is how much is too much and if there is a formula to use.  I have looked at the Ram dual disk 9 1/2 " and also the 168 tooth aluminum flywheel with the 1/4 " replaceable insert but what I am not sure of is would it be better to have a good gripping clutch or a more stock type due to the take off and having to slip the clutch more.  I autocross more than I drive it but I drive it to the tracks and home again.
