gr8vet
Here ya go; instead of doing the complete Vintage Air system at $1200, I opted to swap out the compressor, condenser, of course a new accumulator, new orifice, and new hoses. Like everything else I have learned in life, just do it your self and it works out better. Crimp kit cost me $140, Vacuum pump ran $75. Compressor was $198, Horizontal flow condenser $148, hose kit $139. Bought the bracket kit, did not like the way it set things up so I modified it. Hose kit did not have fittings to mate to Accumulator not lower condenser back to evap. I just cut the old hoses and made a splice into the old hard line from condenser to evap. Spliced old line with fitting from accumulator, to suction side of compressor using a 12/10 splice connector. Doc's Blocks is a GREAT source for fittings, they have all the odd stuff we Vette people always seem to need.
Old system findings, which I attempted a retrofit 4 years ago with some outside help: Two of the old connections still had old black o rings, not good. The orifice was inserted wrong, upside down, by Local Shop, go figure. Overall maybe 2-3 cups of oil poured out, not much room left for 134a, plus I understand that this can settle in the condenser and make it's efficiency worse than it all ready is.
Pulled vacuum on new system held for 9 hours no loss. I let the vacuum pump run over night to be dang sure any moisture was vaporized.
Added 3 cans 134a so for, understand it will take 4 total, 3 #'s. With 3 cans, fan in front of car, today at 93 in my shop, humidity 85%, I had 175 on high side, and 30 on low side, running 41 degrees at vent, wahoo! Will be better once on road. Barely drags the engine down when clutch kicks in. 4HP to run this compressor, old compressor takes 18 HP.
I think that the old system, if oiled, and o-ringed correctly, and evacuated correctly would operate just fine, not this cold, but good enough.
Do it yourself! Cocoa beach, here we come!
later
tt
later
tt
