I have been led to believe that 0.040-0.045 is the ideal quench.  0.062 + depth of piston in the hole may give you (0.062 + 0.025) a quench of 0.087, which is no quench (squish) at all.
Why are you tring to reduce your static CR?  Were you having problems?  10.50 is not bad.  I run 10.30 in my stroker (8.2 dynamic CR) on 89 octane fuel without a problem.  I do have aluminum heads.
I also heard, that using a thicker head gasket to reduce CR may also increase the likelyhood of detonation.  I have no experience with this, but several on this forum have mentioned this.
I hope others will comment on this, also.
Thank you... very good information! Now I got picture of what you have read and what you have actually experienced.
Currently, I do not have any detonation problems. The engine I refer to has never been run, but is dwelling in my garage waiting to be installed, hopefully this summer.
The motor is a complete crate 383CUI / 360HP with near stock iron smog heads and a XE268H cam. The CR is 9.6:1 and will probably work fine as it is on pump gas. The plan was to install the motor as is and buy an extra set of cylinder heads to do some porting in my free time while preparing my second motor build (a mild tuned 350). I bought a set of ProComp PC3003 aluminium, which turned out to be much better than I expected. The experts have done my job…. not much improvement needed for street use. The intake runners on the ProComp (probably an Edelbrock E-200 clone, Vortec extra high intake runners) are much bigger than on my Edelbrock #27164 EPS (Vortec) and I have to do some gasket matching on the manifold prior to installation. You see the alu cylinder heads could easily be swapped prior to engine installation.
So back to my small dilemma; which head gasket should I use? I have to choose between:
(1)	Titan 0.062” racing copper gaskets
(2)	FelPro 0.041” near stock gaskets
With the 0.041" gaskets I will have approx the same static CR as you. What is your cam overlap?
Best regards
Arne
