DARROW 74
The wonderful pro form carb. 750 vacuum secondaries
First thing that went wrong (new out of the box) carb leaked out of both front and back fuel bowls down into the motor. After talking to several different people who were in the know. I was told to take it apart to see if I could see any problems....I did and all I could see ( being the expert that I am not! and knowing nothing about hollys) was the gaskets looked to be in very poor condition. After telling the factory rep about it he asked that I send it back. Ok got it back, with a note saying that the gaskets were bad. Put it on and ran it. Did not run real well at all. Cutting out at high speed. Float was high, gas was at top of site glass while trying to adjust the level I noticed that it would take a long time for the rear bowl to fill up. well being as I ordered a fuel regulator (After I found out that this carb should not have over 7-8 lbs of pressure, holly reg comes from factory adjusted at 6 lbs.) I guess I have time to take it apart again, Now that I have learned a
little about it I might be able to see a problem.
Well after taking it apart I don,t even think they even took it apart .
lets start with why it was slow to fill the secondary see all the little white particles?
this stuff was plugging up the needle valve.
then the gasket thing
Well you decide
And I paid a lot of money for this new PROFORM.
At least I think I can get parts from summitt to repair and I am learning a lot that I did not know.
And also anyone know where I can get a driver for the screws in this pic
Well you decide
