First, let me start by telling you I have a VBP Dual Mount rear composit spring with Carrera adjustable shocks (on the stiffest setting, 50/50 supposingly), no rear sway bar.
I would like coil-over shocks that need NO fabricating (I do not weld).
Questions:
(1) Can I eliminate the dual mount spring with a set of coil-over shocks?
(2) Will the rear suspension be just as stiff as it is now? (it's pretty firm now)
(3) Will I lose any side to side support/stiffness? seeing the composit spring and the sway bar (if I had one) connect to the trailing arms.
(4) What are some high quality coil-over shocks (that would be a bolt-on application) you guys can recomend?
Thanks
The car is a street car, I do drag race it frequently but never autocross or roadrace the car
Questions:
Thanks
