Well on to another problem that I just cannot explain! I had a Transdapt sandwich adapter on so I could run an oil temp guage. I could not get it to stop leaking no matter what I tried. Finally I said forget it and removed the adapter and screwed the PH30 filter back on to the OEM bypass. I cranked it up and blew oil past the seal. When I say blew I mean blew!!!
I figured Ok I unscrewed and reinstalled the filter several times while trying to fix the adapter leak so I must have damaged the seal. No big deal other than a huge mess to clean up. I went and bought a brand new PH30 filter and some oil. I did all the typical practices of cleaning the surface and yes making sure the old seal was not stuck on the motor. I tightened the filter hand tight which is what I have always done to the OEM bypass (Adapter removed). I had the wife crank the car up and within 10 seconds of watching I saw and heard a big pop from the back top side of the filter and here came the oil gushing out.
Pressure has always been 75lbs at idle and drops down to around 50 when warm. I am running a GM ZL1 pump and a moroso pick up. When the first filter blew my guage was showing 75ftlbs. The second time (New filter) I don't know what the guage was because I was laying on the ground watching the filter for leaks
Can this go bad??? Cause a problem like I am describing?
I am at a lose for what to do or what happened. I swear I couldn't make up the bad luck I am having. I am not an incompotent man or at least I don't think I am....
I am scared to say what else could happen.......
Any ideas?
Wade
Any ideas?
Wade
