Inspired by My Bad 79, and a very loose and leaky stock set up,I jumped.I couldn't locate a manual gear so I used a powered rack, from a 88 Citation giving me 2.7 turns lock to lock.I've looked and searched this for a long time, decided to use Riggs 74 set up with two Grand Am tie rods.The center link made from 3/16 plate,with 26mm spacers at the rack( the same thickness as the tie rod ends) ,the tie rod ends have a 1/2 thick 1 1/2 dia.washer welded to the back side,these are drilled & tapped 12-1.25 mm to use Grand Am rack bolts & jam nutted on the back side.An extra plate added to the front for strength also 3/16 thick.
The brackets holding the rack are made 1/4 plate,with 1 in. plate for the part that mounts the rack to the frame plates. These had pockets cut to let the rack clear
Everything gusseted with 3/16 plate.
The steering shaft ordered from Speedway, all Sweet u-joints and 3/4 in. shaft,I used weld on joints, because double d was only available in chrome,and as we all know chrome won't get ya home.
The column shortened 2 in. and a rebuilt power steering pump,lines and fittings ordered from Speed Direct.
A test drive this morning showed a little leak(retightened fittings and its sealed)but wow what a difference,NO SLOP:thumbs: no longer drives like a 78 Ford pickup!!!!
What do ya think?
Gimpy
What do ya think?
Gimpy
