turtlevette
The Turdle
and does it work ok? How much do you have to rev the engine to get it to start charging?
the stock replacement unit i have now doesn't start charging unitl i rev the engine a little. I measured the #2 field terminal at the plug and its hot all the time as it should be. I meaured the #1 terminal that is supposed to be switched by the ignition and get nothing with the ignition on or off. I think i have a wiring problem so i thought i'd try the 1 wire instead of tearing into the steering column.
Is your idiot light burned out?
there is no idiot light on a 75
I don't have a vehicle wiring diagram handy. What's the factory mechanism to feed the alternator field current at low RPM/low alternator output conditions?
GM made it about as simple as it gets with the 3 wire. Output, field, and excite. The 1 wire thing was invented by a bunch of guys that were too otherwise occupied to figure out how the hookup a 3 wire.
I said: "The 1 wire thing was invented by a bunch of guys that were too otherwise occupied to figure out how the hookup a 3 wire."
I rest my case.
I rest my case.
I read through several threads on CF. I don't understand why a 1 wire alt gets such bad press. The guys using them have no complaints. My alt has been effectively in 1 wire mode for the past year or 2 and it was just the other day that i noticed slow starting that let me know there was an issue. I'm hoping the more modern alt will excite more quickly and easily with a modern electronic regulator. What Gene said about the air gap is a good point. These things are way better than what our cars came with.
