Jclgodale3
- Joined
- May 13, 2008
- Messages
- 348
- Reaction score
- 0
From the appearance of your flexplate, why don't you reuse it?
It would not bolt to the 11.5" bolt pattern Turbo 400 torque converter. It was way to small
You sure you don't have another set of holes on the Flex?? I have....
maybe check twice before spending $.....
they are on a index, off the points of the others...
:hi:
Nope...not even closeFrom the appearance of your flexplate, why don't you reuse it?
:hi:![]()
Correct.TT...trying to understand. The newer crank, having no additional wieght to balance the back end of the crank is the reason they put a flexplate with a welded on weight to "counter" that lack of balancing?
CorrectIf so, then would putting a "non weighted" flexplate on it not throw it out of balance?
CorrectWouldn't I need the larger 14" 168 tooth flexplate with the same weight welded to it?
Whew! I need to quit second guessing myself because that is the flywheel that just arrived! 168 tooth for a 1 piece rear seal, with a weight welded on it that will bolt to my Turbo 400 converter...:cussing:Correct.TT...trying to understand. The newer crank, having no additional wieght to balance the back end of the crank is the reason they put a flexplate with a welded on weight to "counter" that lack of balancing?
It is not so much a "lack of balancing", as it is GM's chosen way of balancing the 1 pce engines
If you have made no internal changes to the engine , then you need a stock 1 pce seal ext balance flexplate in the size of your choice with the 11.5" convertor pattern.
Love it when a plan comes togetherWhew! I need to quit second guessing myself because that is the flywheel that just arrived!
