Yellow73SB
- Joined
 - Mar 24, 2008
- Messages
 - 1,201
I have 5 calipers right now, all 1.75/1.88 four piston calipers. Now I wouldn't be asking this if the alcon caliper I just bought was the same as I already had but it isn't, one is for 1.25" and the other is 1.375
I believe the older style wilwood set is for 1.375 rotors, I can find these rotors off ebay for pretty reasonable prices, usually front 12.625-12.9ish in diameter. I found some red devil chromoly ones that are coated that are supposed to weight 12 pounds less also. But I'm not worried about that
What exactly makes one caliper more desirable than the other, both appear to be forged, both are older style from a cup car such as a NASCAR or ARCA car. The alcon looks nicer. They should be just as rigid as each other, obviously don't have the more distributed load of a 6 piston caliper though
I was able to find a decent deal on a late model motor, and it is going to be making some pretty serious power compared to what I was originally planning.
My thought was to take the inserts from the alcon calipers, which I believe are titanium, and put them in the wilwood calipers. I'll measure the pistons first though to see if I can just put the alcon pistons in the wilwoods
The car is going to have 3, 3" ducts going to the brakes also, might add an inline blower on the top line also
Alcon caliper inserts
And the wilwood calipers, I had to take out the heat sheilds where the rotor goes to clear the rotor, heat shields from pads are still there
