what electric low pressure pump ?
I have yet to hear a silent electric fuel pump that mounted externally to the tank.....the one mounted to rear frame with a piece of rad hose around it, is about as quiet as it gets....and it's for a FI setup....
the ones I have bought for carbs make more noise than a diesel next to me....
:crap:
if intank you can use a 83-84 f-body vin code G pump. It was a low psi pusher pump used with mechanical pump to eliminate vapor lock. Fits most gm intank fuel sending units and made around 4-6 psi
I need an electric low pressure pump. What is a good silent one to run ?
Fuel Pump ??? The quietest one ive ever owned is the Holley Gearotor 125 gph Fuel Pump in www.jegs.com catalogue. It is TOTALLY silent with the engine running and very quiet without the engine running. Next on the list for quieteness, would be the Holley RED Pump at 90 gph which can only just be heard with motor running. Both are 7 psi outputs .
P.S. I have a used low mileage Holley Gearotor 125 gph Pump available for sale . Excellent condition inside and out. , if interested.
