Jsup
- Joined
- Oct 31, 2008
- Messages
- 810
- Reaction score
- 0
I think what I am going to do is buy an Ostrich, there's a Bluetooth version that is currently available.
With that, I am going to also pick up Tuner Cat, or Tuner Pro RT to tune, I will leave the Ostrich hooked up and run the car off it.
Finally I'm going to pick up Datamaster or similar program to run logs.
I'm going to learn this stuff myself. And continue to work with Greg.
Anyone have any preference on software? Tuner Cat? Tuner Pro? Data Master? Scan Pro? what do you think?
Jsup, Since you are committed to the GM stock computer, I think you are on the right track with the Ostrich. That should give you alot of the capability you are going to need. I used Tuner Pro, and Scanner Pro on my GM MEFI ECU on Ramjet before going to the Gen 7. I thought it was a good choice and the price is right.
Bullshark
Thanks. I'll do that. Everyone I talk to that actually took the time to learn the stock ECU, is telling me that there is no good reason to go to any aftermarket ECU for my application. They all independently tell me the same thing, the GM ECU is more detailed and more refined for my application.
They do admit that it is more complex than aftermarket, but if I take the time to learn it, I will be better off in the long run. I spoke to six or seven people independently and got the same conclusion. FWIW, I didn't ask that question, I simply opened the door by saying "I may have to go aftermarket" and let them answer.
