cascotty
After installation of the dual mount rear spring set-up and the transverse mounted front spring I knew that there would be lots of adjustment options to obtain the suspension I wanted. What I'm finding so far is that this trial and error process that may be really time consuming. I haven't found any adjustment manual in the VB&P stuff
Initially during installation the front was set-up with the springs mounts on the next to softest setting. Softer settings are the inboard holes. The front remains in this setting and it seem okay to me.
During installation the rear was set up in the softest setting ( see the wear mark on the attached photo). I was hitting the bump stop hard in the rear and my first adjustment was to change it to the next to firmest setting.
The rear spring adjustment was a lot better. After the adjustments discussed further along I think that it was over done and I need to back it down a notch.
Next I decided to adjust the ride height up to get some more suspension travel. Initial set-up was 27 1/4 to 27 1/2 inches from the floor to the top of the fender at the wheel opening. I raised it to 28 1/2 inches all around. Note my wheels are 27.1 diameter so about stock. This felt like a big improvement. I had to tighten the adjusting nut about 2 inches to get 1 inch lift. Clearly this added a lot of pre-load on the spring. Hmm maybe too much?
I was also concerned about the length of threads showing, but there is no min./max adjustment indicated in any of the installation material.
Next up, tire pressures. I spent sometime trying to find a recommendation for tire pressures, but mostly the available info. is for stock cars. I wanted something for my Nitto 555's but there is nothing other than a max of 44 psi. I did find this rule of thumb :
(Vehicle Weight in lb/100) + 2 psi at heavier end + 2 psi all around if suspension and alignment are stock.
Example: Stock 911, 3,000 lb. (3000/100) = 30 psi Add 2 psi all around = 32 psi Add 2 psi to heavy end = 34 psi at rear With modified suspension, the result is 30 psi front, 32 psi rear.
I checked my pressures cold (not so much in California) and found them at 25 to 27 psi. I thought I must of lost some pressure over the last 6 mos. wow. So based on the above rule of thumb - sort of - I put 36 psi in the fronts and 35 psi in the rear. This made a dramatic change, the ride was a lot rougher. It also made the slow speed turning a lot easier. After about a 20 min. ride and 45 minute cool down I checked pressures and they were up 3 psi in the front and 2 psi in the rear.
So next I took the pressures down to 33 psi all around and went for a drive. It is now a lot closer to feeling like I think it should. I also check pressures with out a cool down and the fronts were up 2 psi and 1 psi in the rear.
I'm thinking that the next adjustment is to take the rear spring adjustment down one notch. Also, maybe lower the car to 28 1/4 to reduce some of the preload. I think I can still play with tire pressure too. A good long drive to get a better feel for what to do next could help too.
