SIXFOOTER
What does a Stud Girdle do for you?
Used in conjunction with guide plates? Stand alone?
With high valve spring pressure and a cam with lots of lift, the rocker studs will deflect away from the load, possibly breaking a stud. That reduces the amount of available lift. So one cure is to install a stud girdle. Splits the load among all the rocker studs. Another way is to install shaft mounted rockers- easy on a SB, not so easy on a BB.
Guide plates are just that- guide plates. they keep the pushrods from deflecting to side loads.
