Criste
Active member
The car has been sitting for about 15 months, so this leak may be related...
I don't think it was leaking before, but discovered fluid leaking where the speedometer cable goes into the transmission. Checked and found the fitting hold the cable was loose. Problem is the fitting is nearly impossible to reach so it can be tightened. Is there a special tool?
Thanks, Jerry
'82 700R4
Thanks, Jerry
'82 700R4
